A lot of good progress lately.
Engine coolant flush and replace (HOAT)
Transmission fluid drain and fill, new filter
Oil change
Fender flares treated with a heat gun (1300 degrees) to restore color (pics attached). It works on that little plastic corner triangle at the front of your door windows, too.
Replaced drag link, steering dampener (Monroe SC2928)
Upgraded to ZJ tie rod. Looks great, much stronger than stock. I bought it from O’Reilly’s - it’s the Moog brand and I paid way too much but I wanted to get it done right away and it was already painted for me so I rationalized it.
I replaced all related connectors, tie rod ends, and added Lucas Red n Tacky grease to all the zerks.
I set the toe in per the method recommended by Stu, seemed alright but I took it straight to an alignment shop this morning so I will see how close I made it. I also stopped by Lowe’s for some square tubing so that later I can do it using Blaine’s method that was posted by Jerry.
Hopefully this will eliminate the vibrations I’ve been experiencing. I will test it once it’s finished at the shop in the next hour or so.
Here’s before on the fender flares:
In progress
After
(Not 100% fair comparison because before is in the sun and after is in the shade)
here’s that corner piece (don’t have a before but it was very faded)
steering parts!
