Full articulation with ranchos 10 7/8” shocks. Weight of the Jeep is on the shock. Look at all that space! The rear wall gets pushed back big time with highlines
12” shocks eventuallyOh man, what's the plan to fill that gap?
Fox I imagine?. Will the towers need to be raised?12” shocks eventually
Yes absolutely Raised towers. The joints on the short arm still aren’t maxed out even. @jjvw was your concern about 12s on a short arm the amount the shock will swing in the tower? Because the joints have enough room to move for 12” of travelFox I imagine?. Will the towers need to be raised?
I set it aside and will sell it most likely. It’s not hard to get off with the spare. There’s 2 bolts that hold the license plate part on with wing nuts. So you just twist the 2 wing nuts off by hand and pull it off.
Awesome! What’s your zip code I’ll get a shipping estimateIf you’re willing to ship I think I know a buyer![]()
They would fit! @taylormade73 hint hint wink wink37's. haha. JK
The issue is splitting the travel in half and fitting the upper mount under the stock inner fender.Yes absolutely Raised towers. The joints on the short arm still aren’t maxed out even. @jjvw was your concern about 12s on a short arm the amount the shock will swing in the tower? Because the joints have enough room to move for 12” of travel
Ah I thought you were saying the short arms would be an issue. With the highlines it seems 12s would fit although I’m not sure the inner fender on the highlines is that much higher right above where the shock tower goes but nothing that couldn’t be cut.The issue is splitting the travel in half and fitting the upper mount under the stock inner fender.
The only reason I got mine too work is because of the modified 12s and because I secretly added a bit of ride height when I moved the upper spring seats on the frame.
With highlines, you have much less of a problem. But you will have a good amount of tire rub on the upper spring seat.
Another thing to be aware of is the arm length and jacking. When you get to the 11"+ realm of shock travel, the arm angles at droop get really steep. For example, if the front tire is climbing a ledge with an undercut the tire can get caught, pushed downwards, and backwards rather than climb up- leading to a lot of potential damage. A longer control arm reduces the possibility of jacking by reducing the control arm angles.Ah I thought you were saying the short arms would be an issue. With the highlines it seems 12s would fit although I’m not sure the inner fender on the highlines is that much higher right above where the shock tower goes but nothing that couldn’t be cut.
Awesome! How’s your dad going to keep up?!
Once I finish up my Jeep for Moab I’ll build his exactly like mine. He’s got genright highlines, savvy corners, and currie steering waiting for me to install!Awesome! How’s your dad going to keep up?!
Do the genright highlines push the rear fender wall back further than stock height genright fenders? Might be a better question for Alex since he’s had them bothFull articulation with ranchos 10 7/8” shocks. Weight of the Jeep is on the shock. Look at all that space! The rear wall gets pushed back big time with highlines
I’m not sure by how much but I imagine they are still pushed further back due to removing the stock battery bracketsDo the genright highlines push the rear fender wall back further than stock height genright fenders? Might be a better question for Alex since he’s had them both
Yes they do. You can see in the photo the difference - The sliders were flush with the non highline.Do the genright highlines push the rear fender wall back further than stock height genright fenders? Might be a better question for Alex since he’s had them both
