AbsolutelyMind if I steal 1 or 2 of your photos? I'm processing a bunch, but since you did the perch relocation and I didn't, I want to show that.
I have not though I’m not sure what would be gained by eliminating itWith this rear track bar mounted so high, our roll center is really up there... I'm thinking about running without the rear sway bar. Have you considered that?
Sway bars are beneficial.With this rear track bar mounted so high, our roll center is really up there... I'm thinking about running without the rear sway bar. Have you considered that?
Just spoke to Jason... He is in complete agreement, fwiw.
Do it! It transformed my jeepyou guys are making me REALLY want to get these brackets installed (they are sitting in my garage, ready to go).
They are, but we've changed so much of the geometry that the stock bar certainly isn't performing as designed... It's just a thought.Sway bars are beneficial.
We'll see how far I get this weekend. I have a trip planned for the weekend after mother's day (leaving the 13th). I want to have some de-bug time before I go too...I'm to the "big stuff" point. My dash is mostly installed, and I need to put in the fuel tank, re-install sliders, bolt the seats in, put the driver's fender on, hood, cowl panel, tailgate, tire carrier, check bumpstops because I added 3/4" spacers and new shocks, etc. I probably should make a list. Exhaust mods would be a killer...I have a bolt on turn down though....Do it! It transformed my jeep
I did mine with 4 90* bends and a few straight bits. Wasn't too bad but I do suck at welding the paper thin material. I lost about 7 decibels getting it to come out the rear.We'll see how far I get this weekend. I have a trip planned for the weekend after mother's day (leaving the 13th). I want to have some de-bug time before I go too...I'm to the "big stuff" point. My dash is mostly installed, and I need to put in the fuel tank, re-install sliders, bolt the seats in, put the driver's fender on, hood, cowl panel, tailgate, tire carrier, check bumpstops because I added 3/4" spacers and new shocks, etc. I probably should make a list. Exhaust mods would be a killer...I have a bolt on turn down though....
I think mine should be a bit simpler, because I'm sticking with the short arms. I'm gonna need to do something soon anyway...mine is REALLY close to the passenger rear shock. I'm hoping it will be ok though. Its another time suck fab project that I don't need.I did mine with 4 90* bends and a few straight bits. Wasn't too bad but I do suck at welding the paper thin material. I lost about 7 decibels getting it to come out the rear. View attachment 245973View attachment 245974
Good to know. Thank you.They are more stable without the sway bars with short arm geometry correction than a normal janky 4" lift is with both sway bars. I only run a front antirock in the softest setting on mine with mc springs and 14" travel shocks on all four corners. The light anti rock setting forces the rear springs to fully compress onto the 2" bumpstops and also allows the front to fully compress onto a 1" bumpstop. Without the front antirock, it won't max out the rear and with the stock rear on, I have to run the antirock in the 3rd/4th holes to get it to work decent, then it doesn't like to flex but it'll sure corner and can really handle some evasive maneuvers. If you are carrying a ton of gear in back, it'll help it flex with the sway bar in there.
The stock and walker 54227 tail pipes normally do not have Clearance issues. I've replace a bunch of careless exhaust shop jobs with the walker 54227 pipe to fix clearance issues.
I've used a banks as well without any issues. If you take it to an exhaust shop, yank the springs out and force them to build around the parts. Otherwise, they'll hurriedly run pipe right through pinch points without giving it any thought.
Reach out to Team CoCo and see where we are midday on Saturday. Fins is easy to jump onto Are several points on sand flats road.Change of plans for Moab. Instead of driving up today we will be driving up tomorrow. My wife has some work stuff she has to take care of today. I’m curious if I could leave early enough tomorrow to catch some wheeling though.
Sweet. Will do thanks!Reach out to Team CoCo and see where we are midday on Saturday. Fins is easy to jump onto Are several points on sand flats road.
Driving the Jeep! This will be the first time I’ve ever driven it further than 1 hour away from home! Haha but I’m looking forward to it consider how well it drives nowadaysI’m heading up tomorrow as well. Are you driving the jeep or towing?
Me too! Well “me too” to driving it to Moab, the jeep has driven fully cross country twice, but this is the most hardcore trip it’ll have seen this far from home.Driving the Jeep! This will be the first time I’ve ever driven it further than 1 hour away from home! Haha but I’m looking forward to it consider how well it drives nowadays
