30* was the target, it went a little over at about 31*.Looking good!!! Do you know the angle you bent the a pillar at the windshield?
i'm not totally committed to the bent bar across the dash and may put a straight in. i'll be trying to fit an inverted V tomrw.
if you look under the dash you can see the tube is sectioned. i have a 7" stem that will mount to the floor up front and receive the A pillar making it removable from the tub (a footplate will never fit through the dash).
i've looked at internal tube clamps, and might go this route (80$). or i could use some 1.5" for an inside coupling and then a chunk of 2" for a sleeve clamp on the outside..
