I've got a diecient leak from my sye kit. Previous owner installed it so I'm not sure what make it is. All the fluid is on the drive shift at the first u-joint. Is this leaking from the rear seal and does anyone know if a standard transfer case seal will work as a replacement or do I need to figure out which sye it is. There's always a drip off that bottom bolt after driving, but that seal is bone dry?
