What oil should I use for a hot climate in my 2006 TJ?
Fishtaco
TJ Expert
Perth AU
What oil should I use in a hot climate some info says 20/40 others say 10/30. I put 10/30 in should I change to 20/40.
Thanks
The highest recorder temp in Perth is 115.
That is the daily average in the summer at my house with recent high of 122 a few weeks back.
We will be at about 103 today.
That said I run Mobile 1 10-40.
Once I start the LJ up it will not be shut of for 5-8 hours depending on where I am going.
Where ever I am it sits idling with the AC on high keeping it cool inside.
15w 50 Napa full synthetic. On sale this month at 3.39 a quart
Made by Valvoline (at least it used to be) and is a perfect oil for your conditions and engine. The 4.0 isn't exactly Ferrari tolerances even when brand new.
Good luck
Out of curiosity because I live in a different (pretty hot) country. What do you consider extremely hot conditions?
110-120f is common for my local Southwest deserts. The hottest temperature ever recorded on Earth, 134 degrees in Death Valley California, happened only 300 miles from me.
Diego Garcia Atoll, British Indian Ocean Territory, 126.
Jubail Saudi Arabia, 128.
Never do I desire to return to either in this lifetime.
10W-30 is what the engineers at Jeep recommend and is what I run in even extremely hot conditions.
While this is a true statement, the 10w-30 recommendation is more likely a bid to squeeze another 0.1 mpg for CAFE standards than because the engine was actually designed with 10w-30 in mind. The AMC inline sixes that our 4.0 is directly descended from were almost certainly designed around 10w-40 or similar. CJ service manuals from the mid-80s indicate 10w-30, 10w-40, or 20w-40 are all acceptable.
That said, I run 10w-30 myself.
