What is a NP231 Crawl Box?
SSTJ
Lifetime Supporting Member
SE USA
I'm entering my info into GrimmJeeper.com and am confused about Step 3: Underdrive. One of the options is "NP231 Crawl Box". Is this some sort of add-on option for my NP231-J transfer case? Googling now, but you all are always so much more helpful.
The crawl boxes are made from the planetary and a new or some portion of the 231 case to put it between the back of the trans and front of the current t-case. Adds about 8" of length and a 2.72 additional ratio which gives you 1-1, 2.72-1 2.72-1 and 7.39-1 for ratios depending on how you shift each case.
Is this similar to the the 203/205 doubler
There use to be a few companies that offered a crawler box kit for the 231 where it used the front section of the t-case with the gear reduction and you cut off the side for the front drive.
It went between your transmission and t-case to act as a reduction box. Most of these companies either are no longer making them or no around anymore.
There are also reduction boxes like this https://www.northwestfab.com/blackboxunderdrive
Reactions: SSTJ
