Tried to use my winch to move an empty swim spa. Like my wife said, "Epic FAIL"!
Line to spa. Combination of a tow strap, a tree saver, and a Harbor Freight tyedown strap (!!) employed around the thing.
Strap low against the bottom structure.
This fence post was my undoing...
Line to Jeep
Line to spa...
Try #2
Try #3! All it did was bend the shit out of the fencepost...
Even though this failed, it was a good learning experience as I used EVERYTHING in my recovery kit. The tow strap, the tree saver, two soft shackles, two clevises, my snatch block, my TRE Coozie, and even my e-tool to dig around the fence post to remove it from the ground.
This should have worked famously, it didn't because the fence post wasn't even CLOSE to strong enough. I'm guesstimating the spa weights in the 500 to 600 lb range empty. 3 guys put it in where it is, they used rollers to roll it across the lawn, and once it was on the plastic substrate, they slid it around like it weighed nothing. I figured I could move it by hand the same way, but not even my burly son-in-law and I could get it to budge - hence the winching attempt. Its like it has glued itself to the plastic panels its sitting on.
Two questions:
1) I'm certainly open to critique of anything I may have been doing wrong, unsafely, or sub-optimally. Yes, that is a Harbor Freight tye-down you see as I didn't have quite the length with the tow strap and tree saver combined (coupled with a soft shackle). I wasn't able to stress test the lashup fully due to the bending fence post!
2) Son in law and I are going to try something completely different tomorrow - but what could I have used as an anchor at the snatch block that would have held up to the strain?
Line to Jeep
Line to spa...
Try #2
Two questions:
