Various things this early morning.
1- Loosened up the TC lever and manage to reach “N”, but not 4L. Linkage is out of tweek and lever wont reach the 4L position on the TC case lever. Tried to adjust the linkage but the bolt turns hard and will not loosen up, thread is bad. Inside tub TC lever hits the end stop, TC lever not near the correct position for 2L, needs to go a good 10-15deg more. 4H engages too soon from “N”.
2- Opened up the engine bay to look at the Alt Belt, noticed a couple of non OEM wires around, and started removing them and ended up with a pile of wires all over the Jeep. See photo.
3- Spray Greased things all over and the TJ is looking much better.
Found the tank guard plate corroded badly, need R&R.
4- Air filter, not OEM is badly clogged, needs R&R. Need OEM housing not there.
5- The underbody is in good shape, front floors are bad but fixable easily.
6- Chassis has been repaired ( I knew ). Fixable if body is lifted, but now looks sturdy and 4x4 worthy.
7- I am very happy to see that this TJ is fixable to very good shape conditions, I made a good deal when I got it, no doubt, TJ is 100% original, no mods, other than one of the doors has a manual window mechanism installed, the other still electric ( Dont care doors to be sold ).
8- Radiator looks fairly new, will do the job for now.
9- Started lubbing all over the place so I can lower the windshield, the way I ride it all the time.
10- I AM HAPPY !!!!!!!
