They do. Early in this thread you should be able to see the extra layer of steel on top of the frame where the GR mounts sit.
Thanks, jjvw! I didn't look closely enough. It looks like only the front conflict.
Front:
Rear:
Ya'll and you're lack of accuracy on important shit is maddening.
Rear upper what?
What new mount and how do you get a frame gap?
What did you order? Have you installed them?
Just the rear lower isolators for the sides. At the time I wasn't aware of the small bit of extra I could have gotten. They've been installed a while now, maybe a year ago now?
Did they come with the inner sleeve in them? Did you buy crown or other.
I think it was dorman, but I can't find the email. There's no inner sleeve on the lowers, it's a washer bonded to the rubber.
edit: https://www.4wheelparts.com/p/crown-automotive-body-mount-bushing-52002659/_/R-BKMN-52002659
Ok so I don't need the sleeve? Some places show part 52002659 had this in the description:
So I assumed that it was needed.
- Sleeve PN 52002661 Not Included
This is part 52002661
I still need to find the part number for the upper bushing on the rear mount.
Someone is. The rear mounts at 4 positions, 2 at the rear bumper, 2 over gas tank crossmember and the one under the grill have the shorter top puck than the ones down the sides under the doors. At least that is what I recall. I have a 100 or so scattered about so I'll double check to verify later today.Are we missing something?
Correct. You would need to shim the mount up, tack it, and then fill the gap on the mounts that need it.
Yeah, that's in the upper half, you'll cut it down by ~1" but once you're down there you can mark exactly where to cut.
Is it of any concern that the diameter of the shorter rear upper body mount bushings is smaller than the hole opening on the raised genright body mounts?
Taller body mount upper bushing and sleeve
Shorter upper body mount bushing and sleeve.
That's precisely why I don't use them. Check the height above the frame side mount for us.
This is what I was talking about and what my intention to do was...this was back at post #35No, the bottoms don't swap exactly between the uppers. I use the whole rear mount which lets the body mount welded to the frame move even higher. You can swap the lower onto the upper of the regular side mounts with some tweaks though. To do the countersink, just put the bolt in the mount, set that on a short piece of 1" .120 wall tube and mash it flat with the shop press. Make a perfect countersink to use a flat head bolt.
