Howdy, I really need some suggestions for a good single din stereo mounting kit that will actually HOLD the stereo in place. I've tried two so far and pretty much one good bounce and the stereo comes loose in the rack. The factory rack was broken so I tried replacing it with a couple of different ones that fit my 1999 Jeep Wrangler TJ. Basically, both are really nothing more than a faceplate bezel and cannot support the weight of my typical single din unit, so a couple of bumps and a loose stereo. Can anyone suggest an installation kit to fit that is more "heavy duty" and provides support of the unit from the sides or maybe top/bottom and not just faceplate? My stereo is typical single din JVC KD unit. It looks like the factory rack had side extensions from the faceplate extending back into the dash that would allow the stereo unit to be attached to the sides by screws.
I appreciate you suggestions.
