Got the floor permanently mounted today. Need to pick up a few more fender washers to finish my installation
The hatch over the engine needs a litte adjustment too. I used a pattern bit in my router to "trace" the opening in the old piece, so I know its in the spot where it was. I think it was wrong from the factory or this piece has been replaced before (doubtful). The corner of the wood is trying to occupy the same spot as part of the air cleaner cover. I'll have to clear that out a little bit. Once I get everything all arranged properly, I'll put a good coat of penetrating epoxy over the top and side surfaces too. Getting closer to walls!
