I'm no expert,but if bolt elasticity(losing their clamping force) is an issue could harder bolts work?hardened washers?
I'm guessing you used grade 8?
The 9/16 JJ has 33 degrees of articulation and the 5/8 has 30 degrees. The next larger bolt has only 23 degrees of articulation.
How much was the juice?
The last time I had the front wheels off the ground I noticed just a hint of play in the ball joints. So, knowing what was coming I picked up a set of rebuildable Dana 60 ball joints from Dynatrac to try out.
These are the low profile (lower joint) version which works with the RCV's that I run. When I installed the RCV's, I had to trim the stock lower ball joint to clear the big orange ball. These should clear without modification.
Anyone have any experience with, or insight into, these things? Is the juice worth the squeeze?
I had heard good things about them but that was prior to Dynatrac selling out to the ring whore.
Was not aware - Randy's?
2022 | Dynatrac Products, Inc. | RANDYS acquires Dynatrac and its impressive ProRock series of high-performance axle assembles, driveline and suspension parts, and brake kits. |
2022 Dynatrac Products, Inc. RANDYS acquires Dynatrac and its impressive ProRock series of high-performance axle assembles, driveline and suspension parts, and brake kits.
https://www.randysworldwide.com/history
YEP they did a lot of buying in 2022. Carli, ICON, and Dynatrac.
Isn't ICON sold at Harbor Freight?
