Yes on eBay. They are not cheap anymore ($70ish). I use the OEM switch with the aftermarket rocker. I painted the back of the switch so the dash light didn't shine through the white and into the "on" light.
I swapped my lower panel for one with more switch locations today. The heated seat switches will get hooked up when my new PRP seats get here. I've got another switch for my spot lights coming to fill the top hole. I'll use an aftermarket rocker on the OEM switch there too. The lower areas are for future lockers (front & rear), air compressor, and power inverter.
They are single step switches. The base switch is the OEM fog light switch with a different rocker. I think the PRP seat heaters are just on/off.Looks great! Are the seat heater rockers 1 step or 2 step switches?
We tried but mee maw done came out da house hollering bout it smelt like a damn pole cat got into some bad meskin food. Told us we uh best clean this here shit up for pa paw gets home puts a whoopin on us till next Sunday.
"fixed it" once using a fishing bobber tied to the arm.
Here is the thread that shows the steps to add the light bulb. About halfway down. https://wranglertjforum.com/threads/electricwizards-2000-tj-sport-build.14165/page-12#post-336835There is a thread where someone added a second light, but I don’t remember who/where.
You can also use XJ Cherokee fog light switches. The only difference is the wire coloring.
Did you replace the fan, too? Most likely the cause of your voltage divider (resistor pack) failure.
I didn’t. The fan was replaced sometime after I bought the Jeep in 2016. Maybe sometime in 2017 I’m guessing.
Polished and smoothed up the fenders and started on the paint
Finally get the new one home??
Ya.. he got home last Friday.. drove it 16 hrs to Nashville and stayed with my sister.. then finished the last 4 hrs next day..
Were you there??
XJ Buddy had already "fixed it" once using a fishing bobber tied to the arm. I'm like "are you sure that bobber plastic is rated for fuel? I expect it is just going to dissolve." And sure enough that's exactly what happened. Apparently the top part of a fishing bobber is made from a different type of plastic, because It was still sitting in the bottom of the tank.
Hopefully the second sentence applies to my post as much as the first sentence does.Redneck ingenuity at it's finest right there. I probably would have tried a similar thing
Picked up a oil drum seat… matches my table now…just need to paint it maybe.
Installed the 3D printed dash vent with ball mount and the deeper upper storage tray.
Here is the link.Can you share where you aquired the dash vent with the ball, or maybe the 3D print file?
enjoy the better shifting
