This morning I mounted the hard lines for the fuel system along the driver's side frame rail. Because I installed the Genright raised body mounts, I couldn't just use Adel clamps at the top outside of the frame rail because the raised body mounts interfere. I started by re-mounting the gas tank and skid so that I knew where the rear end of the lines needed to be. With those ends located properly, I used an Adel clamp to mount them to the frame:
With that in place, I did some custom bending to get the lines just right, and then I used Adel clamps mounted to the tops of each of the raised body mounts. I tapped each hole drilled for a 1/4-28 screw from the bottom, since I couldn't get the tub raised high enough to do it from the top:
Here are the Adel clamps for the rear two body mounts:
And for the front body mount, I used 1/2" tall aluminum spacers on both lines to get some space between the abrasive stainless flex line and the body mount:
I just had some lunch, and I'm headed out to work on the center console slots for the cutting brake handles. Stay tuned!
