1999 TJ intermittent no start
Jody Ray
Oklahoma
my wife has a 99 TJ 4.0L automatic trans. it began turning over but not starting a while back after being driven and warmed up good. let it set a while and it will eventually start up and she can drive away and no issue. I researched a bit and determined the CPS was going bad so I bought the best one i could from napa. problem seemed to go away but started doing it again. finally did it to me at O'Reillys one day so I just bought another CPS and changed it. fired up and I drove off. continued to have same issue and today she started it and as she was pulling out of driveway it died and wouldn't start. I took air breather off and sprayed starter fluid in it. still wouldn't start. pulled a plug wire and stuck a new plug in it to check for spark and it has spark. also I've put a fuel pump in it just because. im at a loss.
Is it throwing codes? If so, what are they?
I'd be inspecting the wiring harness for damage personally. All it takes is tiny little break in the wiring.
Reactions: hear
You're
You say you spray starter fluid into the intake manifold and it doesn't start, yet you have spark when you test the spark plugs? That doesn't make sense.
I roughly ran thru wiring. I didn't see anything glaring. have not put a meter to it though.
Well if you have spark, and you have fuel...and it's not starting...then it's either compression or timing.
I'd be testing fuel pressure. Verifying spark. Then a compression test. Inspecting the cap, rotor and plug wires. Checking the battery voltage at rest and while cranking.
it runs fine when it does run. I don't believe it's either issue.
