How far to press in Dana 30 inner seals?
Vtx531
Kalamazoo, MI
How far are these seals supposed to be press in? Are they supposed to be flush? For some reason I thought there is supposed to be a shoulder but I kept pressing and it just seems to go further and further in and now looking at the other side, I don't see a shoulder.
I put anaerobic gasket maker on the metal-metal part so it is probably setting up pretty quick. Not sure if I need to try and punch it out and start over.
Is this pressed in too deep? The red stuff is excess sealer but I didn't wipe it off yet.
There is a inner lip in the tube, but you'll have to use a digital caliper accurate to 0.0001", and measure the axial distance from the differential carrier bearing race to the theoretical seal landing shoulder within the tube. Then insert a mopar alignment rod, and using UHMW plastic rails, and a string-and-pulley suspension system, float the alignment rod into position without gravitational deflection. Position the seal at the axle tube entrance, and using a CNC-machined seal driver (±0.0005" tolerance), tap the alignment rod gently until an audible change in tone indicates the seal has made contact with the internal landing lip. For confirmation, deploy a borescope down the axle tube.
There is a inner lip in the tube, but you'll have to use a digital caliper accurate to 0.0001", and measure the axial distance from the differential carrier bearing race to the theoretical seal landing shoulder. Then insert a mopar alignment rod, and using UHMW plastic rails, and a string-and-pulley suspension system, float the alignment rod into position without gravitational deflection. Position the seal at the tube entrance. Using a CNC-machined seal driver (±0.0005" tolerance), tap the alignment rod gently until an audible change in tone indicates the seal has made contact with the internal landing lip. For confirmation, deploy a borescope down the axle tube.
Can confirm.
I found this pic I took earlier. That looks like the shoulder in there past the rusted area. I don't remember if these seals have ever been replaced but if they were- maybe the old seals were't pushed in all the way by whoever did the job last time. Wish I would have taken a pic of the old seals before I punched them out.
If I press the seals in deeper than last time, the seals will be riding on the exposed rusty/pitted/corroded part of the axle shaft and LEAK.
Is it possible the factory tool doesn't set the seals in all the way to the shoulder either? That would explain why I read a lot people are getting leaks shortly after completing this job.
This reply makes me feel reckless and dirty.
Reactions: tworley and lBasket
Don’t press them in any further.
The point at which the clean bore and the wet/rusty area meets is where the back of the old seal was sitting.
It looks like you are at least to that point, with the new seal, if not a bit further.
You definitely want the new seal contacting the clean area on the axle shaft.
I’d say you are most likely right there.
Maybe smear with a bit of grease on the clean area of the axle, insert it in, pull it back out and see if it shows a line where the seal will ride on it.
I know it’s a bit of a headache sometimes getting the hub/axle in and out multiple times, but peace of mind…
Good idea with the grease. That's exactly what I was thinking about the rusted area. I knocked out the passenger seal to take a closer look again.
Removed
Reinstalled Now
