Imho a lower profile winch like the HF 9500 and relocating the control pack under the hood makes for a much cleaner install.
Wow that is a winch what the weight on this.
Heres a SuperWinch epi9.0 on my cut factory bumper. I also have the Savvy winch guard on it with some Hellas.
Heres before the Hellas
These are rear bumper endcaps, they fit on the front if you cut it straight. You can also buy endcaps that square off the sharp edge that is exposed when you remove the factory front endcaps.
The winch guard is bolt-on and fits the factory bumper mounting holes. Heres a link. I did have to do some fitting to clear the stock swaybar that was a pain, but it bolted up after a little work with a dremel.
Im not sure i would buy the winch hoop at the price point listed, when i bought this winch hoop it was $149 in 2022.
If i recall, the winch mount is the cheap Rough Country mount. All smashed together with some big ass grade 8 bolts. Nothin' fancy.
Picture taken right before throwing in the metal recycle bin and buying a nice Warn lightly used winch. Sorry, might be mistaken. D
They are a bit steep for what it is, seems to be other options though. I just wanted to see what a winch on oem bumper, now you guys got me want I g end caps and hoops wth! Lol you all are fired!!!
