Anyone tried to convert rubicon air lockers over to cable operated?
Your time and money is better spent converting the Rubicon air lockers to aftermarket lockers.
I, in no way advocate nor condone this idea. Just highlighting its existence
There is a guy out there who is trying to and has made the Rubi Lockers cable operated. I found these posts about 4 months ago and held on to them for a rainy day. Enjoy.
https://www.facebook.com/share/r/1BsYPkSTSz/?mibextid=wwXIfr
View: https://www.facebook.com/share/v/1D7TYDAMf3/?mibextid=wwXIfr
View: https://www.facebook.com/share/v/14rS7SHVAGb/?mibextid=wwXIfr
View: %5BURL%5Dhttps://www.facebook.com/share/v/1D7TYDAMf3/?mibextid=wwXIfr[/URL]
View: %5BURL%5Dhttps://www.facebook.com/share/v/14rS7SHVAGb/?mibextid=wwXIfr[/URL]
Nothing against what he is doing but he has a few challenges to overcome with his engagement side. If he doesn't spring load the engagement side so the flip lever compresses a spring(s), then it won't shift until there is differential action that turns one side more than the other to line up the clutch teeth to engage them. On the bench with them lined up is good for video, not so much in real life where you have to turn to get one side moving further than the other.
If he has already figured that out, good on him.
The original OX lockers "worked" with no issues as well and they were sans load springs. That is until there were posts from every owner on the forums sniveling about having to hold the shifter while turning until the teeth lined up and they could lock the shifter in. Think of it like rev matching a manual trans to shift it. Until the gears line up, it won't shift.When you go through his posts about it, he says it's out running trails and being tested with no issues so far. So there may be something of the sort that just isn't shown.
Bleepin jeep used blood pressure squeeze bulbs on an old fc build![]()
I think @Rickstar321 did that on his old axles.
