To make the B8525 work I'm going to need a minimum of a 3" suspension lift. I need some time to get real numbers here though. Currently, I have three sets of springs that can be experimented with, including 1" H&R, 2" BDS, and 3" Nth degree. That said, I know the limits of using the H&R springs. Using those and a 1" spacer up front, the best shock travel I can expect to get is roughly 5 up and 4.21 down, using the B8516.
If I switch to the B8525, and more suspension lift, I'm only gaining, potentially, .57". This is the biggest lesson I've learned so far with sticking to a 31" tire. That is, you really have to be willing to work a lot to squeeze out 9.25" of shock travel without having your Jeep look like it's sitting on stilts. Frankly, I had aspirations of making it to a 10" travel shock. However, this is a case where, as the saying goes, the juice isn't worth the squeeze. All in all, I'm content that I was able to make it close to my goal, while having a Jeep that looks proportional and performs exceptionally well. Lastly, I haven't given up hope yet that my original goal can be obtained!
