01 TJ skid plate drop
STEVEINKC64
Kansas city
I have an 01 wrangler TJ automatic and just installed a 3" suspension lift. If I lower the transmission skid plate 1" to reduce vibration will that effect or drop my shifter lever and 4wd selector lever? If so, are there kits to extend them?
Technically Yes by a negligible amount as both shifters are attached to the trans/ TC which are supported by the rear mount which is attached to the skid.. It wont be a problem for you. A body lift can be a different story.
