Just getting back to finding time to work on jeep, I have replaced the loom on several wiring harnesses around the engine block and decided to really look at the sensors on the transmission to see if they were contaminated with oily dirt build up. the sensors on the transmission looked good, loom was in good shape and no build up of oily dirt, but when I got to the speed sensor at the outlet of the transfer case (at drive shaft) it was packed with oily dirt and took some time to clean it up well enough to be able to pull the connector apart. on the sensor itself, on the inside where the pins are located was half filled with a greenish oily substance, so I pulled the sensor and cleaned it out and also cleaned the wire connector side which had some wire insulation deteriorating. after cleaning it all up I put it back together and went for a ride, well now the sensor was not working because I was not getting a speed indication. ordered new sensor and installed. the issue with the jeep having issues while driving forward seem to have gone away, but I still have the issue with reverse. Not at first but after more than 5o miles driving I have intermittent reverse issues. no power in reverse!!! if I give it gas it will stutter and kill, will start right back up and will go in reverse with slowly applying gas as it backs up but if I give it too much gas it will stutter and try to kill. looking for suggestions!!! The transmission is not slipping while in reverse.
