i get yah.
i'm stuck at a 17" wheel for the 1 ton JK steering components, but have no desire to use an E class tire.
the MTR is a C in 35x17x12.5 and i think Nitto has 1, choices are slim. but C is it, no D's, no E's.
i have other options. i could laser another steel ring to use as my anti-cone/centering device. i could roll and weld something on there. but the UHMW is so light and easy to work, it seems like a possible option. i would do some fit test's to determine what might be the proper thickness to be able to clamp well and reach the torque value required.
i like that thought of securing the device between the clamp bolts, and i'll steal that.
my rig is destined for a trailer. i cannot risk having to leave it in the field (2hrs away) if i'm unable to drive it home, so she'll get towed out to ensure i can get her home no matter what occurs. this is what even made the idea of the bead-locks viable to me, no highway, not a huge balancing issue for low speed off road use. and 1 less bead to bust for field fixes.
i do appreciate you taking your time to lay out a proper explanation. thanx again.
