1997 Jeep TJ no fire
ArkansasTJ
Clarksville, AR
Drove it home and parked it. Went out next morning and motor would turn over but wouldn't hit a lick. Gauges don't move. Has never done this before. Checked and no fire to spark plug. Replaced crankshaft position module, still doesn't fire.
All of the above advice is gold. I had a similar crank no start situation that ultimately ended up being a loose connection at the ignition coil, pulled connector apart, cleaned it, reconnected and that was it.
My advice, do the above from easiest to hardest. In my case I didn't check that connection (easiest) until I'd tried many more difficult and costly options that didn't solve the problem.
Keep us updated, especially if you solve it. 👍
  • Face Palm
Reactions: hear
