I have a 1997 TJ that came with ABS. About a decade ago, I disabled the ABS by pulling the relay when I replaced my Dana 35 with a Dana 44 that did not accommodate ABS. The rest of the ABS is still in place. I have been running a 15” Big Brake Kit for over a decade as well.
I recently started having an issue with my brakes, they simply don’t break a well as before. It is most notable in 4 low. While it has always been expected and noticeable with heavy tires and 4.56 gears, it has become more and more noticeable on the trails and now the street.
The brake pedal is now spongy as if there is air in the lines and makes a “whoshing” sound as it is pressed.
So far I have bled the brakes starting a right rear and working my way towards the master cylinder. There are no air bubbles and I have clean fluid at each wheel. The discs and pads are in good shape and there is no sign of a leak at any of the calipers or connections.
Any thoughts on where to look next?
