Dear fellow wrangler enthusiasts,
I've purchased my first wrangler a couple of weeks ago; 1998 TJ, 2.5 L, 5 speed manual gear and it's pretty much stock, apart from some exterior parts. Whilst test-driving, there weren't any apparent issues with the engine. A few days after I bought it though, the engine started behaving weirdly. About 1-2 minutes after starting the engine (cold start) it starts surging/hunting. The RPM goes very irregular and sometimes drops to as low as 400 before it shoots up to >1000 again. This happens both when the engine is idling or when driving in gear. It doesn't happen always, but about 95% of the time. When it happens when driving, I'm usually still in 1st or 2nd gear and doing not more than 30 mph. The RPM's drops and the engine starts surging as if it's not getting enough fuel. Depressing the throttle does sometimes help it get back to normal RPM's, but definitely not always. I've also noticed that when the car is parked with the engine idling after starting, an increased amount of condense (water) is coming from the exhaust as soon as the surging starts.
When I stop the engine and start it again the issue is almost always resolved, and I can drive 100 miles without any problems. When starting the engine when it's still warm (e.g. after a short stop at the gas station), it doesn't have any issues either.
Since I've bought the car, I've had it serviced by my local garage. The usual oils, liquids, and filters have been replaced and a general check on the vehicle was done. The mechanic said there weren't any fault codes active. An internal engine cleaning additive was also added to the tank. He recommended driving it around for a while and seeing if it would help at all. That was 2 weeks ago and so far it hasn't helped at all.
My best guess would be that the engine problem originates with a faulty/dirty TPS, MAP or O2 sensors, but I'm not sure where to start in all honesty.
Does anyone have experience with similar problems or can give me some advice on where to start looking?
Mick
Mick
