1998TJ problem:
Superkev
Aylesbury England
Hi all, I’ve tried to download a video of what my jeep TJ is doing, but can’t download it. But when it’s hot she won’t run without labouring with it revving up and down with no power. I’m at a lose on this know. I’ve changed the throttle body, the injectors, the crank sensor, the cam sensor, the dizzy, the fuel pump, New leads plugs and all the normal stuff, I’ve had the ECU checked which came back as all good, done a vacuum smoke test which came back perfect too with no leaks. Any help would be great cause I’m at a loss of what else to do.!!​
Post it to YouTube and copy the link here.
What's your fuel pressure through the power loss?
Done a compression test?
Check your intake bolt torque?
-Mac
Won't start when the engine is already hot? Like it will start fine in first start of the day, but if you drive somewhere, park and try to restart it, it doesn't start then?
You need to explain the symptoms in more detail.
Reactions: macleanflood
