2.4 coolant weirdness
Guitarguy
Kansas City
Hey guys so I've got a 2006 TJ with the 2.4 and a 6 speed. I love this thing to death but recently, it's been giving me some coolant troubles. About a week ago, i was in town in stop and go traffic and the temp gauge went above 210 for the first time since I've had it. It usually sets just below 1/2 or 210 but it came up to almost 3/4. I was going to get gas anyways so I pulled into the station, started filling up and popped the hood. The coolant reservoir tank was shaking like crazy and it was filled up to about 3 inches from the top. There wasn't any smoke or anything and it wasn't discolored like oil or gas had mixed into it.
After it settled, I waited a few minutes for the engine to cool off and the level went back down to normal. I don't hit stop and go traffic much since i live in a small town but I did a coolant system flush hoping it would solve the issue. I didn't have another episode and the temp never got hot again till today when I was in line at CVS. The coolant wasn't high when I shut it off but the temp was well above where it usually sets.
As soon as I got moving again, the temp came right back down. I'm not loosing power or hearing any weird sounds and I don't have white or blue smoke coming out the tailpipe. I did however smell a faint sent of coolant after I parked it when I got home today. I also have a check engine light on for an evap leak. P0456 is the exact code I believe. Any ideas on what this could be for the coolant thing or both issues if you think they may be related?
Replace your radiator cap and gas cap. They probably aren't related. You could probably carefully clean you gas cap and the code might go away. The radiator cap is too cheap to mess with. That's what I'd do to start.
First, what you saw with the reservoir tank was normal.
A radiator overflow tank collects the expanding coolant that is heated by the engine and recycles it back into the coolant system once it loses enough heat.
If you get things hot enough it will do this Violently like what you experienced.
You are describing an overheating issue, check to see if your fan clutch is working properly
Reactions: mushdogs and Chris
