Thanks all for the info! I’m about to head out camping for the weekend. Jeep will stay parked in the garage. I’ll start by testing the fuel pressure Early next week and follow back up.
Like Jerry and Pagey said, it’s likely both the regulator and fuel pump hushing by the symptoms I’m having
*edit* just did another test where it has been sitting for about an hour, turn the key on once, let the pump prime and then turned it over (didn’t turn the key off or on, just on and then crank). Took maybe 2 seconds to fire up. Then I shut it off, let it sit as if I was getting gas for a couple of minutes, then turned the key to on and then cranked it and it fired right up. So it may not be the regulator after all... but still don’t understand why it wouldn’t start after I did a 15 mile drive earlier today..?
