Tank is installed with the new parts from axis. That’s where I’m stuck this time trying to figure the wiring out. It’s all I have left for the install.
I was crazed at your point to hear my engine fire up in my engine bay. I wouldn't mess with your gauges yet and get the starting wiring correct first. Gauges will be another major headache you can deal with once you're on the road was my viewpoint.I’ve got the j1939 plug In the firewall. So just need to run power to the computer key and fuel tank
It's really not too loud. I still haven't ran an exhaust on mine.I should probably put the exhaust on before I do that. Haven’t gotten the piece that mates from the DOC to the banks system yet. Lol. Neighbors might find that to be a bit loud
Have you messed with Quickserve yet?So the wife gave me the deadline of the 30th to get this thing running.
I watched the repower garage video on YouTube and realized I was way over thinking this wiring issue.
Spliced into the red wire off the ignition switch. But that provides constant 12V. So it’s not that one.
But was able to realize I’m getting codes
729 03 001 and
3597 02 001
Also got the no bus on the instrument cluster
This is so radProgress over the past couple of days. Changed the mega bracket out to accommodate the ac compressor.
Remove the power steering bushing from the old bracket and install on the new one
Removed old engine mounts
Test fitting the engine and tack weld the new mounts to the frame
