Incorrect. The TJ Rubicon ride height is the same as a regular TJ.
That being said, a stock Rubicon will rub its tires bit at full articulation with the sway bar disconnected.
I was misinformed then. My bad.
This Rubicon spring discussion has gone around and around on this forum. When I decided to order springs I called our local Jeep dealer and contacted Rock Auto Summit and a couple other places and the oem part number was no different for any TJ.
I stand corrected.
Incorrect.I do believe that the Rubicon came with a 1 inch spring spacer to accommodate the 31’s.
... Or maybe I’m confusing the 1” wider flares?! ...
Incorrect.
The front Dana 44 does have a 1/4" thick plate welded to the axle pad to serve as a bit of bump stop extension to help reduce the tire rub. But it isn't quite enough to clear 100%.
Correct!
The Sahara also has the 1" wider flares, but their's are color matched to the body.
I think I seen in an earlier post that you may put the Rubicon flares on. I put them on mine a little over one year ago and Summit Racing had the best price I could find for new at that time.
I must have gotten lucky. When I cycled my suspension, I removed the jonce bumper and jacked the tire up until the jonce cup touched the spring perch and my tires on both sides did not touch anything??
Did you also turn the wheel lock to lock while it was stuffed with the front sway bar disco'd?
Incorrect.
Nope.
I obviously had the sway bar disconnected but did not turn the wheel.
Did you stuff just one tire? That's when it happens. I've seen a few threads with photos that show it. Mine was too far from stock to personally verify, but my measuring shows that it will happen.
I don't think it's a huge problem with the stock size tires. A little rub is fine since it should only happen momentarily at slow speeds.
I thought it was a 1/2" plate, but you two are the Rubi owners, so I could be smoking my lunch.
You were my technical consultant, you obviously dropped the ball [emoji23]
