Hi All -
Any experts out there on the 32RH automatic transmission? I recently rebuilt mine for my 1998 TJ and just re-installed it.
I can start it in park and neutral only, so I think the shift linkage is adjusted correctly. I can also roll it backwards in neutral with the engine off.
However, it moves forward in neutral with the engine on. Also, when I shift into reverse, it shifts into reverse and starts to move, but then stops; almost like it is binding. I am thinking the reverse band is fighting against a stuck forward clutch staying engaged.
Any thoughts? Maybe a stuck forward clutch piston?
