Assuming you have a 97 (I skimmed the thread, and it sounds like you do) it will be cavity B11 at the computer for the solenoid control. There is always 12V to the solenoid on the RD/LG wire with the Jeep running. The computer provides ground on the OR/LG wire when it wants to turn on the lockup. Check for continuity from the computer to the OR/LG wire on the TCC plug, and check for 12V on the RD/LG wire with (I think) the key ON, but possibly with the jeep running. Also check fuse 11 behind the glovebox. Power to the TCC is through that fuse.
Checking for the switched ground from the computer will be more challenging.
The connector at the trans will have two wires, the OR/LG wire which goes to the computer, and a RD/LG wire.
