This got me thinking, the diameter itself shouldn't make a huge difference from a 33 to a 35" as far as axle strength and braking strength. Of course you need more clearance for the bigger tire, and gearing needs are different, but the general consensus is that you are usually fine with a 33's, with stock brakes and even a stock Dana 35 (no locker), but not with 35's.
Is that based off of simply the diameter difference, or the assumed increase in weight?
I ask this because there are some stupid heavy 33's, like the Toyo M/T, and Falken M/T, that weigh more in a 33", than say the Cooper STT Pro does in a 35". As an example, the 33" Falken weighs 75 pounds, whereas the 35" Cooper weighs 67 pounds.
Thoughts?
Thoughts?
