I attached two videos of my jeep. Both videos are at the same time but just a sound comparison. I also took off the belt so that way there weren’t any other sounds or noises from the parts all moving. I did an engine swap in January from a local you-pull-it. The motor itself has 120000 miles on it. Wanted to see if anyone knew a diagnostic on how I could fix the problem or relieve engine failure for a little longer. (I’m in college now and want to put a crate motor in hopefully in two years) thanks!
