Definitely 5.13 for 35s and the 5 speed and freeway use.5.13
So unless your state has 75mph+ highways and you spend a lot of time on them
Cruise control + proper gearing makes maintaining a speed easy, especially with a manual transmission. I usually aim for 70 or whatever the majority of traffic is. It takes a lot of fuel to sustain anything higher than 80. Above 85, my fuel economy goes to a single digit.I do a lot of long road trips, all the cool places are far from Florida.
One common thing i have noticed on any highway in any state is that, unless you can find a semi to tail, doing a speed limit is a pita. It is a constant deceleration, merging, and acceleration.
The most peaceful cruising is when you speed by 10-15 mph or below the speed limit by 5-10 mph.
In speeding scenario you are mostly in the (left) passing lane, and it is a smooth sail, unless some slow ignorant dumb fuck hugs the lane to himself... But, you have no business of being in the passing lane in the Jeep to begin with.
In slow scenario you are in the (right) slower lane, everyone goes around you, even merging traffic traffic from the ramp has more time to adjust to you. And that is why i have started preaching 65mph top speed to all jeepers.
65 mph = jeep is more controllable and quieter, ride is smoother and peaceful. Travel distance over time difference is meaningless on shorter than 10 hour trips.
So if highways speeds is a deciding factor in gear selection, aim for 65mph.
The biggest issue I think people have is not downshifting frequently enough. When passing slow cars on a two lane road, sometimes a 6 to 3 downshift is called for. Trying to pass someone while only doing 3000 RPM is not going to be easy. And climbing mountains on the freeway often calls for 4500 or even 5000 RPM sustained.
When I merge, I run it right up to redline (~5200 RPM) before shifting. Much safer to merge at the same speed as traffic, as opposed to the people that panic and merge moving much slower than everyone else.
Just be aware that's about the equivalent of 5.38 on a 5 speed.I have the 6 speed manual, it seems like 5.13 is where it's at for 35s - hoping to get to both before next year.
The 6 speed has an OD of 0.84, but the 5 speeds have an OD of 0.78/0.79.
Although there is part of me that wants to go straight to 5.89...
I agree. It really depends on where you are driving. I-90 up the east coast with heavy traffic? You're going to be changing speeds a lot. I-79 through West Virginia? Prepare to downshift. I-29 in North Dakota? Set the cruise control and just run.It is not about that, sorry if i painted a wrong picture with my words.
I saw words "road trip" and "highway", to me it means a prolonged period of time on the highway. If you get a kick out of merging, shifting, flooring, braking, and reshifting for 5 -10 hours in your Jeep - more power to you.
My days of racetrack and doing 120mph on the freeways were over when i purchased this Jeep.
Do you have 4.10s currently? If so, 5th gear and 4.10s have exactly the same drive ratio as 6th gear and 4.88s. So pretend 6th gear doesn't exist. That will give you a very good feeling for how 4.88s will be on the freeway.I wouldn't mind driving both the 4.88 and 5.13 with this transmission to get a better feeling - it's hard to picture the difference without!
4.88 x 0.84 = 4.10 x 1.00
I recently had 5.13s installed (6 speed/35s) and I drive a lot of freeway (SoCal) but I've always preferred to have more gear rather than less. While the rpms are slightly higher than the factory 4.11/30.5" combo on the freeway, I like the way it moves and if anything it will help me drive at a more reasonable speed.
define freeway.... freeways in TX and CA are two different things
