Hello to my fellow Jeepers!
I have a 2005 stock Rubicon auto with about 149k miles on it. I need some insight on some problems I have been having lately. The following may or may not be all connected.
Alright so last summer I had about 140k miles or so and the spark plugs had never been changed to my knowledge (bought Jeep about 5 years ago with 97k miles). I had engine cylinder 6 misfire. I drove from point A to B a couple of times to get it fixed (twice [shop fixed it but didn't fix first time so I had to drive it back]) as I needed the Jeep fixed ASAP for a trip I was taking. 1 year and no problems or abnormalities except for one thing: I noticed a rattle in the exhaust system; likely damaged catalytic converter or other. Im ok with this.
Fast forward to a couple of weeks ago. I threw a P0137 and P2096 code which are O2 sensors (and possibly cat(s)) - also okay with this as both prolly needed done. I cleared these codes with my own tool hoping it was just a glitch and needed nothing (but still planned on replacing all 4 O2 sensors). Engine light came back and threw p0137 and p0133. Cleared em again and now is just p0137.
Now, I have checked all fluids regularly since I have had the Jeep including ATF which has never had to be touched and looks/smells clean, etc. The last time I had checked it was roughly 5 days ago when I had to use as a daily for a few days while my other vehicle was in the shop for insurance claim (turkey - go figure).
Fast forward to yesterday morning:
While waiting for O2 sensors to come in (ordered all 4), I figured the only damage I could do driving with bad O2 sensor(s) is decrease fuel mileage and possibly hurt the cat even further (and the code could have also been due to cat based on my research). Anyway, I was pulling out of my place of work and I got 100 feet and the transmission (2005 TJ, 42rle) would not catch in Drive all of a sudden and was almost as if it was stuck in neutral; reverse also did not work. I managed to get it going again and drive it 100 feet back to parking lot where it happened again. Parked it, opened hood to check ATF to find that the fluid was LOW (at operating temp). I added some ATF+4 through dipstick tube, started it back up, and checked it while running. What I found was very very odd. Once it was between hot and cold markings, I noticed that every time I checked it I would get MIXED readings; low, "sweet-spot," or literally NOTHING. I shut it off, checked while in park to find the same mixed readings. I started it back up, cycled all the gears and checked again while running to also have the same results. I went to start it up again and it would not start at all - no clicking or anything. I bad a fully charged jump pack on me thinking it was the battery (bran new Die Hard Platinum) and it still would not start, so that was not it. I checked under the Jeep near the rad and saw what looked like the trans line had a weep in it but old (greasy etc) but it was definitely the trans line to rad. However, this spot, although weeping and looking old, does not appear to be a spot that would leak ALL ATF THAT fast. Haven't had time to crawl under since then cause Im currently working and now down two vehicles and trying to figure out transportation lol.
So, my question is (or questions) for the experts on here: Could these be related? Is it possible something is clogged like torque converter or something which is preventing ATF to flow to trans, giving in inaccurate reading? Obviously my trans is toast most likely at this point. Based off this info, should I even consider repairs? Trans, cat(s), torque converter, starting issues now, and possibly more? Seems totaled to me.
I have literally never has a single problem with this vehicle up until now and would be a shame to lose it after all I have done to it (mostly interior/exterior upgrades that dont affect the geometry or mechanical workings of the Jeep.
Quick update: Just crawled under the Jeep and trans fluid is everywhere; covering the entire under carriage. Come to think about it, I have noticed a burning smell the last few days I have been driving it. I think it's safe to say the trans 42rle in this one is toast.
Next steps / recommendations?
Thank you ALL in advance and God bless.
