My shift linkage lever is working, I'm able to pull it up to 4h, N, and 4L but it's not engaging in the transfer case and I'm essentially stuck in 2h. No dash lights indicating changes anymore either. It was always a little bit off and the positions on the shift lever didn't totally match when the 4h and 4L lights would come on the dash. I'm thinking this is because I have a 4 inch suspension lift and stock z linkage and brackets so it's kind of off and mounted too high.
But anyway, I've tried to adjust the rod in the z linkage by loosening the nut and shifting to 4h and 4L, then tightening the nut again, but when I do that it won't shift back down from 4h or 4L any lower. When it's in 2h and the shift lever in the cabin is all the way down, there's only like a quarter inch of rod sticking out past where the nut tightens. But it always engaged before and it still appears to be shifting the transfer case, just now with no results.
Does this seem like a linkage issue, maybe a sensor that's keeping it from engaging if it's controlled electronically, or something with the transfer case? Any ideas would be appreciated. Oh, and all of this was done with the jeep parked and in neutral but 4h and 4L always engaged for me at rest before.
