Good evening all. I've been lurking here a bit and decided to ask some of the pros on here what the heck is wrong with this thing. No codes except a few previous from 02 sensor, evap, crank pos sensor, but those codes disappeared awhile ago and never came back.
Startup cold flawless.
Runs flawless.
Shutdown and start up right away, flawless.
Shutdown wait about 15 min will only crank.
Shutdown wait 30 min will start and run flawless and sometimes may start a tad weak then run flawless.
I like throwing a few parts at things before diagnosing too much if I think the parts need replacing anyway.
1. This has a new unknown pump that I swapped and was supplied with when I bought it do to a poor fuel level sending unit. Pump has maybe 3k miles on it. It is loud and seems to be louder than when I 1st installed it.
2. New Crank shaft sensor
3. New Coolant temp sensor
4. Bosch 4 hole injectors
Fuel pressure test is at 88psi at idle and will hold around 88 psi. From what I understand with the 4.0L is FP should be around the high 40s and/or low mid 50s. So I am wayyyy over that. Could this be just a FP regulator issue? The pump is noticeably loud and if I use the pressure relief valve on the FP tester the pump will quit down a bit as the pressure is released (while running).
Best Options? Replace whole fuel assembly? Or replace FPR on top of tank? (The metal one). Shall I replace both, but with a bosch pump and whatever FPR?
Any help would be appreciated. I am kind of a Toyota and Rotary fan, but I want to support to my home c and run a little American, but this thing is 10x more of a pain than my 94 RX7 lol...
Help!!! I promise I will let the forum know what fixes it, if I ever get there. Seems to be common these days not to finalize a thread.
Runs flawless.
