There was a TSB issued for the 43 codes, they are fixed by replacing the valve springs. The factory's first batch of the TJ's valve springs was bad, they were a little too weak. I had the same problem in my previous '97 TJ and replacing the springs completely fixed all the 43 codes, misfires, etc.
Yes--I am aware of the TSB. I even researched it when I was experiencing the same 43 codes. However, replacing a sensor or two (and even checking the Ohms and resistance) is easier than pulling a head and replacing springs. A new CAM sensor, CPS sensor and coil in my jeep and I haven't had a 43 code in 70k miles.
All three work together to determine the firing order.
