Hello,
I just purchased a 98 TJ which has a hard top on it. The seller also gave me a soft top and a Bestop "Bikini" top along with two "L" shaped brackets and a header bracket. I "believe" the soft top is ripped and may need to be replaced, however he did not have any of the "hardware" for either top. At this point I'm not sure what I have goes with what.
I "believe" the brackets go above the doors, but have no hardware, how does the header bracket attach to the Jeep, my herd top has latches. Are the latches separate? I think these are all for the Jeep Roof 1-3 pictures where 1 is over the front seats, 2 is the rear window and 3 covers the rear seat and trunk, do just the Velcro and straps hold these in place? Is this what is know as the "Bikini" top?
Soft Top Left and Right show where the top is ripped and then a shot of the whole top. Do I need bows for use with this top? Is there a replacement where I do not need bows? If I need bows should I just get a Bestop replacement kit or buy OEM bows and get a replacement top? Does the OEM tops also have removable side and rear windows?
Thank You In Advance!
RInzana
RInzana
