Here is what the current engine sounds like, apologies in advance for dark video, sound decent.
This noise is present cold and hot, idle and at rpm, seems to fade a little on if you rev and let off, then resumes. Engine has good power and runs strong, no stumble, backfire, or smoke.
We’ve done and checked the following:
New exhaust gasket and manifold
New wires, plugs, and dist. cap and rotor
Added engine cleaner to oil, ran
Changed oil and filter. Oil was black, but no large metallic debris. Plug has no shavings either.
Checked all rocker arms, pushrods, and springs. Not loose, damaged, rotate freely, no excessive play
When we pulled the intake/exhaust manifold, actually pretty clean, mainly just carbon. No wet oil, or indication that one cylinder was not working properly.
Going to perform a few more checks like pulling injector wires, draining oil, attempting to extract any non-magnetic metal from the pan, and maybe a little borescope work.
Then, probably pull pan if nothing obvious.
Any other suggestions? Just trying to confirm before pulling the engine. Engine has 178k miles, one owner. Not abused.
The only odd thing about this Jeep is when we first got it, had check engine light on for misfire. We found the # 5 plug gap really small. Fixed and reset, never happened again. Maybe piston contacted it, not sure. Not sure if that can happen, don’t now how much clearance there is between plug and piston TDC. And It was able to jump that much either by rod bearing, or some piston wrist pin issue, maybe the engine would sound much worse or have failed already.
