I’m going to do a few more diagnostics this week.I’ll give this a shot, in your opinion with the 170k miles, is there any chance of making this into a reliable engine? Meaning, all the stuff I’d do to this is just a band-aid until the engine fails? My goal is to make this into a reliable and nice vehicle my kids can drive. And can go down the highway without blowing up or needing a tow truck.
Given that perspective, would it just be best to order a new rebuilt engine, put new clutch in during install and move on?
More research I do, any fix in this would just be a patch until it fails or has another issue.
Whether I get a fully rebuilt or the used jasper engine, seems like a pretty straight forward install.
When you do the compression test, is it best to do it with engine cold or warmed up?
Also my plan was to pull all the plugs and disconnect the injector wires then perform the test. Do you need to remove the air filter?
Spec wise, thinking cylinders should be around 150 psi and within 10% of one another?
Any other thoughts or suggestions?
