For sure, my money would be the bag is fine. If you have ever held one you would know they are very flexible and don’t damage easy. That little dent in the OP photo wouldn’t have made contact.
AC manufacturer rule is you replace that drier any time any part is replaced. I personally have opened hundreds of AC systems and not replaced it and the system still hit 500k miles and was sold without issue. Having spent most of my life maintaining a fleet of over the road trucks I have installed a crazy amount of questionable driers with bent lines, dents, scraps and i would install this one. Most modern equipment has an expansion valve but most of the older stuff I once worked on was all orifice tube and that desiccant material would settle in the bottom of the dryer as with any other contaminant in the system. We always buy a drier but with how hard they are to get on some equipment we only replace them if the system has contamination. 7/10 go in the trash and are only purchased to please the manufacturer of the compressor. You can see in the picture how the inlet tube is way up high and everything else including oil stays in the bottom. Like an oil bath air filter.
That being said, I still stand behind my original statement. If it bothers the OP, head down to the local auto parts store and scoop up another one.
I tried to find one in the garage to open up for some photos but can’t locate one. I’ll see if I can scoop one up.
I don’t have one from any of my Jeeps as I never replace them if the line flush clean.
