The AC in my wifes 99 quit working. She says the blower still worked. The airbag light occasionally started coming on for a couple days, then it would go out. IDK if that is related, but it started around the same time as the AC quit blowing cold.
I went out this morning to troubleshoot.
The compressor clutch is not engaging. The blower motor is now not working.
I swapped the relays under the hood between the horn and AC, the horn worked with either relay.
IDK which fuse under the hood is for the AC, so I put a test light on all of them and they all work.
The fuse box behind the glove box has no power to #7 or #8. They did have power when I installed the radio because I checked them all.
Why would the blower fuse not be getting power?
Any suggestions on my next move?
