Started working on my wire harnesses for the auto swap tonight. I want to go through both of them and check them out carefully before they are installed because I don't have the luxury of installing an auto from a known, good, running Jeep. All my parts were bought second hand (well, the big stuff anyway) from places that part Jeeps out and other people I know. The wire harness is one of those things that is taken for granted, until there is a problem. I also need to verify this harness has cruise. Finally, I run my locker pumps in my engine bay since I've done my Tummy Tuck. I'm going to investigate the harness and see if I can re-route those connectors and use shorter wires, instead of running all the way to the T-case, then back to the pumps.
I got the engine/transmission harness and the main trunk that runs along the firewall. It appears that there is an extra connector on the main trunk to handle the TCM communication with the PCM that my manual doesn't have.
Main trunk and Power Distribution Block...I'm excited the PDC was included, because it gives me an extra. One of them will be repurposed into a relay control center for auxiliary lights and whatnot.
Here is the engine harness, stretched out on my bench. TCM connector is on the left. Its really dirty, some of the connectors are full of oil, and the corrugated wire wrap is in pretty terrible shape.
I have about half of it unwrapped now. I'm using zip ties at every breakout to hold the wires in place and I'm carefully removing and re-installing the Christmas tree pins/zip ties so I can keep them in the same spots. I have about 100 dollars of Tesa fabric tape and braided wire sheathing in 5 different sizes on its way from Amazon. Probably go get some CRC electrical contact cleaner too, to make sure every connection is as good as it can be. I'll inspect for frayed or broken wires too. The whole thing might just get dipped into a tank of simple green and water...I do want it CLEAN, but dipping might be a bit extreme.
Tomorrow, I'll see about printing some of the wire diagrams from the service manual so I can start labeling connectors and comparing the installed options to the options present on my Jeep.
