He uses JJs on both sides of the front trackbar? You should add that info to the joint discussion, since a couple guys were asking why Currie doesn’t do that on their track bars.
Oops... I totally forgot to ask about both sides. I have to assume yes, but I clarify that for sure next time I speak to him.
I tried going to your main page to find the name of your current bumpers and I couldn’t find it. What are they called again and does the rear have a hitch mount? You have quite the project going Chris! It looks sweet now. Can’t wait to see the finished product. Or wait, is it ever finished?
Those bumpers are the Mopar Rock Crawler bumpers. Very rare, very expensive, and no longer made. The rear doesn't have a receiver hitch, which is one of the reasons I'm getting new bumpers... I need a receiver hits for sure!
As for being finished ever... knowing me, it's unlikely!
Why Bilsteins? I thought you've been down that road?
The Bilstein 5125 shocks are required for outboarding the rears. To my knowledge, they are a bit narrower than the standard 5100 (which comes into play given how much closer the rear shock is to the tire in terms of clearance when outboarding the rear shocks), but also the 5125s are meant for lots of travel, where as the traditional 5100s don't come in all the travel lengths that the 5125s do. Dave had mentioned he may be able to find a comparable Rancho, but since he exclusively uses the Bilstein 5125s, I figured I would rather go with what he suggests, since he will know better than I will.
As for the fronts, I figured I would rather have 5100s for the front to match them, because I just feel a bit odd running Rancho fronts and Bilstein rears.
Which is also very interesting considering what others say about the 5100.
I had the 5100s on my old TJ. To be honest, I didn't think they rode all that bad.
The above post was from September so unless something has drastically changed,
@Chris did you decide not to outboard or are you keeping 10” rear shocks even with the outboard?
I think we need more details!
I am indeed outboarding the rears. The rear shocks are Bilstein 5125 shocks with a 12" travel, and the fronts will be 5100s with a 10" travel.
It's worth noting that I had the 5100s on my old TJ, and to be honest, I don't think they rode that bad at all. Maybe not as good as my Ranchos, but it's also been a number of years, so it would be hard to say with 100% certainty how they ride, as my memory is a big foggy, and now there are other variables at play such as my D load range tires, whereas back then I was running E load range.
