I like working on my Jeep as much or perhaps more than driving it. Wrenching is therapeutic and satisfying for me. I bought a tortured and abused TJ and made it a quest to restore it to full glory. Here are just some of the things I did in no particular order. I have also had some painting done, but will have more painting to complete. CJ grill lights will be next. This is about 18 months worth of free time tinkering. It had a period of pimped out chrome bling and decals, but I moved away from my slutty side and have been blacking it out as the sled gets better and better. No need for it to be a painted lady. I have no doubt this list is no where near complete. Anything I omitted I probably did as well.
- Hard Top-installed
- Full doors-installed
- Rear door-replaced
- Re-code locks-finished
- Remove old wiring-finished
- Repair front bumper-finished
- Replace rear bumper
- Re-upholster 100%
- Front rotors and pads
- Rear pads
- Rear emergency brake shoes
- Rear rotors replaced
- Flush brake fluid 100%
- New U-Joints front drive shaft
- Ball Joints
- New pinion gears front and back 4.56
- Totally rebuilt Dana 44
- Totally rebuilt Dana 30
- Lube lockers front and back
- New front chromoly axles
- Left rear axle new
- Complete ZJ steering upgrade
- New wheel hub/bearing MOPAR
- New gaskets and seals everywhere
- New engine
- New fuel pump
- New fuel injectors
- New Cam position sensor
- New transmission
- New clutch system 100%
- 100% rebuilt transfer case
- AA SYE
- Tom Woods Drive shaft
- New four adjustable rear control arms
- New front and rear adjustable track bars
- Entire new exhaust
- All new sensors everywhere
- New power steering pump
- New alternator
- New starter
- New AC compressor, evaporator and condenser
- All new HVAC controls and blend door solenoid
- New HVAC blower
- New heater core
- Injectors
- Spark Plugs
- All Fluids
- Idler pulley
- Tensioner
- Belt
- New Water Pump
- T-Stat
- New Cooling system hoses and tube
- Mopar Radiator & Cap
- O2 Sensor
- 4-Rancho Shocks
- Roof Boom Mat
- LED Dash lights
- LED extra reverse lights
- Four new KC lights
- Washer Pump
- Antenna
- New Stereo with 3 amps, eight speakers and one sub-woofer
- 5 new wheels and tires
- 100% Floor insulation
- 10,000 lbs winch
- 9 additional interior LED cabin lights installed
- LED lighting under hood
