So... I'm in the process of dialing in my Currie/Savvy 4" lift and wonder if having my front uppers extended 3/4"-1" past the jam (more like 1") nut is acceptable or can be improved upon. I know that ca length is a byproduct of setup and what you've got, not expecting them to be equal.
Here's what I've got -
- centered axle laterally w/ adjustable track bar
- checked new steering and track bar clearance. Done.
-Cycled susp. And centered bumps at full stuff. Done.
- checked bump for shocks and tires. Done.
-adjust pinon angle (pinon 15*/ ds 10*) Done. Have not driven yet.
- squared axle to frame, same # both sides.
Should I worry about this? I've read where not more than 3/4" of threads should be exposed. Already lengthen lowers and shorten uppers equal amount to buy back as much as I could. I think.
Can anyone ease my mind or give me a task? Thanks in advance.
