Aftermath of 3” Body Lift
YassinWtheLJ
Fishers, Indiana
Hey gang, So I put on a 3 inch body lift to my LJ....I was wondering if anyone else has run into the problem where there is a rattling sound and/or something is loose. I went around to each mount and made sure the long bolt connecting the mounts to the body were tight and they seemed just fine. But as I drive I will hear a rattle here and there. I was wondering if anyone had advise (or if I should find longer bolts to ensure they’re threaded to its maximum
  • Face Palm
Reactions: NashvilleTJ
Didjooo.....do any supporting mods? Motor mount lift, anything like that?
And really, my big personal question:
Why would you do a 3 inch body lift? Ever?
yeah I put on a motor mount lift and I have a suspension lift.
And to answer your question, honestly to teach their own, I wanted to do it and made sure it was safe and yeah lol
3" BL= NO. 3" BLT=YES.
p.s. The rattle is probably the transfer case linkage.
Welp....good to know stock jeep owners are still sour. I have a valid question and hoping someone that actually does mods can help. Take the hate elsewhere
Sour? In your dreams. Hate? I might point it out and laugh, so it's more like a humorous mood instead of hate.
I told you how to fix your problem, and I DGAF about your opinion of my solution. It's a well known fact by people that actually do real work on TJs that a 3" body lift is a bad idea for a myriad of reasons. Ya, I prefer a stock Jeep, but I have done plenty of real suspension work to my TJ and damn well know a 3" body lift is a shortcut to bigger tires which is all it is good for.
Ditch the 3" lift. Good luck finding someone that thinks it's a great idea.
https://wranglertjforum.com/threads/difficult-time-shifting-after-3-inch-body-lift-install.40451/
https://www.wranglerforum.com/threads/3-inch-body-lift-over-2-5-suspension.286417/
https://www.wranglerforum.com/threads/3-inch-body-lift-pros-and-cons.2282/
https://www.wranglerforum.com/threads/3-inch-body-lift.37497/
https://www.wranglerforum.com/threads/3-in-body-lift.199234/
There's some reading for you.
Do u think if taking it off and putting a higher suspension lift would that be as dumb or would it be a good idea...sorry for coming off as rude I just got defensive lolol
Many people, myself included, run a BL. It actually makes some things easier to work in and sets you up for future mods like tummy tuck. However, I would not go over 1.25”. Here is link to probably the most recommended on the forum. Reason it is prefer is because is solid pucks and will not deform like a rubber or poly puck. https://savvyoffroad.com/product/sav-bltj/
From your profile, looks like you added the 3” to your 2.5” spring to clear 35s. I’m not sure how great it will clear those if you back off to a 1.25” BL. With a 3 or 4 inch spring it should be fine but you will need adjustable control arms, trac bars, and maybe SYE/rear driveshaft (should be ok w/out SYE as have LJ). In short, 35s can be a major expensive rabbit hole.
What is your primary use for the LJ?
Reactions: StefTCK and JMT
Excessive body lifts look goofy, and coupled with big tires just scream "shortcut". TJ's seem to be common for body lifts to accommodate non-tiny tires, but it's via a suspension lift/body lift combination.
If your *only* goal is to accommodate huge tires, I guess a huge body lift works...but jeepers in general know what they see.
@YassinWtheLJ
Boogieman mentioned the shifter linkage.. i would look there first.
I would then check that the fan shroud is completely secure. (I had a knocking noise when a bottom corner of my fan shroud came undone)
Sway bars misaligned and banging on frame?
Bad/failing ujoints?
Last idea... could it be a loose mml bolt?
Reactions: pagrey
I mainly use it as a weekend car...show up to functions and just cruise and also trail
@YassinWtheLJ
Turned out to be a trans mount nut loose!
Thank you sir I’ve really put thought into it and should execute when I get the chance
If you already have 2.5” SL, you can get a 1.5” spacer to get up to 4”, then with a 1-1.25” BL you would be good to go for 35’s and a lot less problems. Of course, there is a list of supporting mods. Best of luck!
With a 3" body lift.....it makes it a lot easier to get to welded the rear upper shock nuts, once the bolts breaks.
You could change the fuel pump with out dropping the tank too. Maybe a small exaggeration. There is a TJ with a 3 in BL and a 6” spring lift that I see driving around. It looks ridiculous but it’s not mine.
Reactions: williambmac
